21 - 30 of 30 Posts
Hello all,
Not directly job related but feel that all the knowledge on this forum can easily answer this question. I have the opportunity to get an older working ac/dc 208 volt Lincoln stick welder for free. My small garage turned fab shop has 240 volt single phase in it. Will it work? Thanks, Rob
Fixed it.
Fixed it.
Lol. Ok, now I understand :)
Yes it will work. More than likely there will be different input voltage taps behind a cover. Check the manual or take the cover off and look for the terminals. Probably worth blowing all the dust out of it while ya there.
Edit: manual says there is different voltage taps. They pull alot of juice! More than 50 amps at 240v.
My reasoning; One cycle, 60HZ on a single phase 208VAC has the same timing period as 60Hz on 240VAC. only the amplitude is different, I think it will work fine.
Save
Discussion starter · #24 ·
208 only listed on the plate is what raised my concern to start with. Usually the data plates will say 240/208 on it. Thanks for everyone's input.
Most welders have a variety of input voltage they accept, depending on its age, it might even be automatic.
My Miller DX200 will accept all the way up to 480V 3 phase, I just wire it straight to the panel and it turns on just like any other day, switch it back to 120V.
It's magic.
Either way I am sure these guys confusing the everliving christmas tree out of me know their electrical much better than me and I don't understand the phases and how they connect and so forth so I'm no good there. But I think you can get it to work, most welders are wired to work on higher voltages more so than lower voltage so I would think its convertable.
If you got questions on welding though, now that I can help with.
Discussion starter · #30 ·
Didn't weld anything yet. I have to go where the welder is and disconnect it, bring it home, then run a 60 amp circuit over to where I'm going to set it up. I didn't want to go through all that just to find out it wouldn't work.
21 - 30 of 30 Posts
