Have a couple questions for you all...
Was at a friends house recently for other reasons and gave the new hvac quick look. Got into a conversation about the time that was spent and what was done (and very likely not done) by the company that installed it.
I try to get into installation side work as little as possible so Im not concerned that I wasn't asked to do it. However, cooling was bumped up 1 ton and no surveying was done to ventilation. Also unclear whether a load calculation was actually done. Variable blower but I am hesitant to check statics and affect the company's warranty. As it stands no hole or plug in the air handler or ducts.
I told them to contact the company regarding a documented load calc and any prior quotes for ventilation modification.
First, am I right to be dumping a company like this? I dont know whether or not any of these things were checked beforehand or afterwards I only doubt it. But I have a feeling that when these questions are asked to the company they could get a defensive response.
Second, based on what you have seen are variable blowers on residential equipment being used as a drop in because they will move the air volume needed even with undersized ducts? Albeit at higher power usage.
Thanks in advance.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Thanks in advance.
