If you look at the attached picture or the below link:
https://goo.gl/photos/hVxhwo5E6fhZ35r77
You'll see that I'm wiring my thermostat to my control board.
There are two main cables.
1) The 5 wire thermostat cable going to the thermostat
2) The 2 wire A/C cable
Heres the problem.
I was messing with this and I forgot where the red and white A/C wires should go.
This is a two-stage gas furnace.
The terminals are
R C G W1 W2 Y2 Y1 O HUM
I believe Y2 and Y1 have been jumpered.
The config works for the furnance and fan when the A/C wires are not added.
When I add the A/C wire I keep putting them into the wrong spot and different things happen.
Also, what controls the two stage heat?
Heres the problem.
The terminals are
