Hi,
I was wondering if somebody could help me with this.
I had a leaking months ago, them somebody came to put a sealer in the system and re-charge it. He loaded 42 Psi in the low side (R-22) the air was working fine for about 1 month, then the cooling drops and it needed more Freon. the second time , he found a leak in a service valve, replaced it and recharged the system again. This time the system took some air and stop cooling after a couple days when the temperature raised outside (about 20F more than the service day). He came back and recovered all the gas in the system, made a 1 hour vacuum to the system, turned on the system, opened the put Freon and after another hour check the system with the digital gauges. I took took couple pictures of the gauges to have a it in record (attached). After the AC unit never could took more than 10 degrees from the intake vent to the outlet, he said the compressor have to be replaced. He did not do any other system check. other data: outside temperature at the time 95F, inside temperature 82F, air coming out of the vent 74F. Eveything in the entire system is very clean and looks new. The system is about 12 years old, but the house empty and the AC turned off for about 6 years.
I am not sure if he really know what's he is doing and I am afraid than replacing the compressor is just the easier way for him to get it working again.
Could somebody please take a look of this and give me some advice about the possible problem in the system
THANK YOU VERY MUCH!!!!!!
