Status
Not open for further replies.
1 - 9 of 9 Posts
Ghenderson
· Registered
Joined
Discussion starter · #1 ·
Heat pump having problems. Ran this weekend then sometime during day it stopped...No compressor or fan motor. Went out and checked electrical..all good. Considered a Cap problem but after testing with anolog meter, no short. Tried checking contacter and shorted my meter however, the compressor tried starting. I put the cap back on and the heat pump fired up and ran. All was good.
Went to work this morning and heat pump turned on and all was good, figured a simple short in contactors. When I got home from the office, unit was off. Pool was warm so it must have run for several hours today. Removed the contactor cover and found one side was obviously burnt. Tried manually pushing in the contact and only compressor starts, no fan. Contact is bad though because as soon as I remove screw driver, contact pops back out and disconnects power to compressor.
Last thing I checked, put an amp meter on the lead off the cap to the compressor and reads 24v when the contact is pressed in making contact. When meter is moved to fan lead of capacitor and contact pushed in, no reading on amp meter.
Could the contact be burned and the cap be intermitting. Would this alliw the compressor to come on but with no fan, the compressore is overheating and causing the already weak contact to disconect. Checked cap again with meter and no short present.'
Ive tried to provide as much information as possible so that a HVAC pro could point me in the right direction. The is a 7 year old unit that was made by Pool Pak Model: Swim Temp V.
Thank you for any help in advance.
Gary
The info is nice but, if you would haveread the rules you would have noticed this site is not for DIY. Sorry :D
Your best option is to call a service company out to service your pool heater. You may have to call around to find someone that will work on it, not everybody does this type of work.
Save
Pack your tools up, step away from the unit, call a pro. It's not wise to be around high voltage when you do not have the proper training.
Save
These guys are right Gary. Your readings make no sense.
By pushing on that contactor you are bypassing all safety switches wich protect not only the equipment but your life as well. Even more so when water is involved.
Whats a life worth these days?
[FONT=Arial,Helvetica][FONT=Arial,Helvetica][FONT=Arial,Helvetica][FONT=Arial,Helvetica][FONT=Arial,Helvetica][FONT=Arial,Helvetica][FONT=Arial,Helvetica][FONT=Arial,Helvetica][FONT=Arial,Helvetica][FONT=Arial,Helvetica][FONT=Arial,Helvetica][FONT=Arial,Helvetica][FONT=Arial,Helvetica][FONT=Arial,Helvetica][FONT=Arial,Helvetica][FONT=Arial,Helvetica][FONT=Arial,Helvetica][FONT=Arial,Helvetica] It takes as little as 30mAmps (0.03 Amps) to kill a human.. Using your amp meter and getting voltage is also a little confusing. And it sounds dangerous.
[/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT][/FONT]
1 - 9 of 9 Posts
Status
