ok...here's the fiasco. i'm trying to work on this dinosaur in a rental property. the unit has been...let's say..."less than pampered." everything seems to ohm out ok and like voltage passes through everything ok, but the gas valve refuses to open when the t-stat is turned up. here's my dilemma: some of the specs are missing from the unit (you know the scene...the yellowed, cracking stickers have long since vanished, some of the metal tags have been thrown out because the renters didn't really need them anyway...) and i don't know the operating voltage for this unit. the primary input is 115 v of course (which it has), but the transformer's putting out 6.7 v. so...if this is enough voltage, the valve's bad. if not then the transformer's bad (i opened it and made sure the leads inside were getting 115). if i replace the transformer with the wrong voltage, i could burn out the solenoids in the valve. 18v? 24v? 6.7v? aaaargh!!! does anyone know the proper trans output for the model 80ua??
