Symptom: Hot / cold rooms. Called an HVAC company.
So I called out the local HVAC company today and explained this to the tech.
I have some issues with the heat pump / system some rooms too hot some too cold. I have never had it checked out since I bought the house. I would like to view it as a short term/medium term/long term solution.
short term - the reason you are here today is to check the heat pumps / mechanicals and see if they are operating within specs. Also a look see at the duct work and everything else you wish to check. Make suggestions.
medium term - remedy any major problems such as duct work. Only with a written report and I will also get 2 more estimates.
long term - replace HVAC heat pump units but not until they expire. Currently Goodman very noisey.
So they checked the mechanicals:
freon okay maybe a little bit overcharged too cold to tell
voltages okay
filters too dense / restrictive replaced with a better solution.
One compressor is a little bit weak. Both have hard starts on them.
duct work
flexi duct not done right
**no boots on register**
suggested dampers
suggested zoning certain rooms
and made a no charge appointment for the duct guy to come out on Friday....
My question is: How can there be registers without boots? They said without boots the air flow is restrictive.
This does not make sense to me.
voltages okay
duct work
suggested dampers
